Slim fan question
enriquez2000
2,411
1,020
Oct 5, 2014
fort collins, Colorado
If i move my stock fan to where ac fan is and install a slim fan where it used to be, can i splice the wires to a relay for the slim fan or should i run completely seperate wiring.
I want to just piggy back off factory witlring but i know slim fan will draw too much and pop fuse
I was thinking sething like this so. Relay is labeled and all that but basic idea here
If you are that worried about it, you could use the fuel pump rewire diagram but use it on your fans using the original power wire as a trigger wire for the relay. Why not just use the stock wiring like Iugrad and amsrn did?
Not sure i can power 2 fans that way is the only reason
I wired two slim fans to the passenger side fan connector. I've been running it like that for a long time without any issues.
Perfect.. ill still run an inline fuse but justvread of people having issues with the slim fans in these cars popping fuses
