slave cylinder or master ? I need help asap please
95tale
110
Jul 26, 2013
hamersville, Ohio
I just put a trans and a new clutch in my 93 eclipse and I blead the clutch. but when I take pressure off the clutch peddle and push it again it has no pressure. so I repeat the steps. I bleed the clutch with a partner then push the slave cylinder in by hand hold it and turn bleeder screw and nothing comes out when I do it by hand. But when a partner pushes on the peddle and I turn the bleeder screw there is air in the line again so I bleed it out. Then push the slave cylinder by hand and it puts air in the line again. Any though on what this could be please I have to fix my car or its going to get towed away
Make sure all your connections are good I had to tighten my ss line to death at the master to get it to seal. Id replace the master and slave if your sealed up good though. I always do them in pairs. I usually gravity bleed mine with a small bottle of fluid then do 3-4 with a buddy on the pedal.
Whats the ss line? And could somthing be loose on the master cylinder even if I didnt touch it when I put the trany in?
Stainless Steel, loose could be check everything else just rule stuff out.
Got ya. yea I just read up how to bleed the clutch and I was doing it wrong I had the person pushing the clutch pumping the clutch and not just pushing it once so thats probably the issue.
