2G slave ctlinder clutch master cylinder
cubedmayhem
94
Sep 7, 2003
kirtland,
Hey if the clutch resivor was dry does the mean the both need to be replaced? The pedal has no pressure. By the way how are LUK parts?
I would try filling it up first, but it means that there is a leak somewhere in the hydralic system. Check up under the dash by the pedals to see if the master is leaking, it will show if it has by stains on the carpet, or just leaking down the firewall like mine was. For the slave, get under the car, and peel back the boot on it. If there is fluid behind the boot, its leaking. LUK made decent stock clutches for my saturn, but I can't comment on anything else. I just got my slave and master from Advance Auto, and they seem to work fine.
On ebay there are act extended slaves, from what im told they can work with the stock clutch. But the are not the whole assembly. does the assembly need to be replaced or just the cylinder?
