Simple BOV Question
boosted954g63
112
Aug 23, 2004
Overland Park, Kansas
Right now I have a Greddy type-s with the 2g flange. My question is will that hook right up with a upper IC pipe that has a 1gen flange welded on?
Thanks Nick
It should bolt right up; the GReddy BOVs utilize the same flange as the 1G BOV.
EDIT: 95Talonized is right, you may need to bore out the bolt holes on your flange a little.
I was under the impression that i greddy flange and 1g flange is different but you could drill into the 1g to make it work.
