Silly washer pump question
craziloki
109
May 13, 2009
York, Pennsylvania
I have silly question.. Simultaneously both of my washer pumps stopped working. My wipers still work, i believe they are on the same fuse. What are the chances of both going out at same time? Thank you in advance!:D
bump:(
well u need to check if u are getting current to the pumps in the back.. . if u are,.. then check if ## pumps are working right.. u will here them humm if they are trying to work.. if they are then u might just have a clog.. other than that idk what else to tell u .. u cna buy both new pumps at advance both are about $20 each. bought a front one today..
(If you havne't done this already) Easiest thing to do is to have a buddy check if he can HEAR the pumps, assuming the bottle/pump assembly is also under the spare tire like it is on my 95 GST.
Next, check to make sure that your water lines coming out of the pump isn't pinched or otherwise kinked/blocked between the bottle and the nozzle.
It happened to me, even though in my case it was mainly because I relocated my battery to the trunk, and the battery weight pinched the line that was running in the hatch area. :p
LOL.. i just put in the new motor for the front pump and for the first time ever the front wipers squirt .. . LOL.. need to buy the back one right now. .
