2G Side skirt
did you document the work you did to alter this part to slow with the dsm bumper, this looks like it would go well with the Op's amazing car.
I have yet to make the cuts on the end. Otherwise, it is straight forward--I have a build thread where I will document it with further detail once I get back to it.
Love the fender flares but I was never a fan of the 2gb side skirts to begin with so I would have never gone through with the addition of the wrx peice . Very nice work though.
Love this look and the fender flares are starting to grow on my each time I see them. What modifications did you have to make to the body to add the flares? Any cutting of the body?
To fully utilize the functionality of the flares, the OEM fenders must be cut--not sure if the OP did so, but I would assume he did to fit the wider wheels and prevent rubbing.
I did the same thing on my Accord:
The side skirts look good with the fender flares. It might have looked weird without them; would have looked wider in the middle of the car.
Wow, ajstrinidad - that looks GREAT! And I am not one for adding extras really; but it works really well. Nice job! The STi lip also appears to work pretty darn well. I kinda wish I had the eclipse front end... as the 2gb Talon one curves to much to really allow for splitters. (At least splitters that look decent.)
Thank you for the comments. Yeah, I did cut the fenders and the quarter panel. The front fender are really easy to cut, but the quarterpanel took a lot more work.
SSooo beautiful..... I want your fender flares.
You used to have the 240z flares on it, right?
Thanks for the comment. Yeah I use to have those flares, but I'm not sure they were 240z flares. I bought the flares from ebay and ended up modifying it. Anyway, in the end, I ended up making my own flares and ended up ditching the ebay ones.
Awesome ride man! What wheel and tyre package are you running (including offset)
I actually make the extension over the wheels or fender flares. The front flares are very easy to put in, but the rear require more cutting than front. The rear also require welding or gluing the two layer of sheet metal if you really want to do it the correct way.
Can u explain where this area is and what u mean? Looks great btw
