side skirt clip
pwnzer
221
Feb 20, 2008
Ann Arbor, Michigan
Recently my side skirt came loose i discovered one of my clips was broken and another one is missing. I have the stock side skirts. Can i get new ones through a dealer and if so does anyone know how much they cost?
you can get them at autozone or advanced auto parts and if not most likey at napa.
Just take one of the old clips and ask them if they have any like it.
so should i just take off the whole skirt for now seeing as its hanging there and held on by the screws on the bottom? and then just run to autozone next week ?
Depending on how tight of a fit the clips give your skirt you may need double-sided tape,which can also be purchased at Advanced and Autozone. I need it when I removed mine,it was coming off because my clips kept popping out.
im more worried about it cracking in the cold the front clips are still on and the bottom screws are still on so it should be fine until next monday when i hit up the dealer or advanced autoparts for the clips thanx for the help with this guys and thanx for the part number ill let ya know how it goes
