VTEC_THIS
- 1,137
- 19
- Jul 20, 2006
Tampa,
Florida
Was going to build this engine but just noticed that the mounting hole on the corner of the shortblock that mounts up to the transmission is completely snapped off and missing. Is there anything that can be done to repair this? I don't have the original piece that snapped off, I received the engine like this and didn't notice it until now. Even if I did have the piece that broke off, from what I understand, cast iron is pretty difficult to weld and doesn't hold up very well.
Yesterday I just received the Wiseco "HD" forged stroker pistons that I was planning on putting in this block. The block is also o-ringed so I'm definitely bummed about the situation. I would really like to use this block, especially since it's already o-ringed but at the same time I'm not going to take a chance and use it if there will be any ill effects. I'm also a bit concerned since the part that's missing holds one of the dowel pins to align the transmission and I don't want this to put any additional pressure on the transmission if it's not aligned properly.
If it matters any, the engine will be going in our 2G and will be putting out 420whp at the minimum with a TRE stage 3 transmission.
Here's a picture to describe what I'm talking about:
