Shifter Cable Adjustment
rlacasse1
2,666
11
Jan 6, 2009
Scott AFB, Illinois
Just read the VFAQ for adjusting the shifter cables. It didn't say what gear the car needs to be in. my guess is neutral. Is this right?
Yep... I do believe it says the closest to upright that you can keep it
Direct quote from VFAQ:
"Center the shifter front to rear and side to side - the spring on the shifter should center it side to side. For front to back, simply check the distance between the rubber stop in the shifter cage, and make the spacing between the stop and the shifter cage equal front and back."
