Setup for e85
arcuri21
47
Mar 6, 2011
rome, New York
I dont know where to post this but, I've been researching and trying to find out what my fuel setup would need to run e85 but I've pick up on that every setup depends on mods.
Mod list..
1000rc injectors
DUAL 255hp in tank
automotive fpr
dsm v3
HTA gt3582r t3 housed 3" outlet
magnus intake manifold
FMIC
bc 272 272 drop ins
stock block
MBC
externally gated
ask specifics because i may have left a few things out here and there.
That's 75lb/min max flow rate. You aren't going to see 75lb/min all the time. I had a built Evo that did 620whp on E85 and a 6262 @ 36psi. 1450cc FIC fuel injectors were plenty big enough and had about an 8-10% overhead left in the injectors. Don't get anything bigger than a 1450 unless you plan to run high-z injectors or get ane aftermarket injector driver box. You will have a VERY hard time getting the drivability and fuel trims dialed in accurately on anything larger.
