Sensors questions for 95 GSX
sypherzero
461
7
Feb 14, 2008
Marion, North Carolina
Alright guys, Im trying to source all of the parts for my 95 GSX. Right now Im looking for all of the sensors in the engine bay Ill need. I know of a handful or so, but if anyone knows of any that aren't on my list, I'd greatly appreciate it. Thanks, Cj.
P.S. It has a manual trans.
Cam Angle Sensor (Is there a certain color green top, black top etc.)
Crank Angle Sensor
Coolant Temp Sensor
IACV Sensor
TPS
Boost Sensor/Solenoid (Do I need this? Will it throw a CEL?)
Your car doesn't have a boost sensor.
What's an IACV sensor?
Not having a boost control solenoid will throw a CEL if it's not plugged in.
JNZTuning.com
I thought it was called the IACV sensor, its the sensor on the underside of the throttle body where the coolant lines are. And on the boost solenoid, Ive seen a few things online about people removing theirs. Will I need one to get it running? Thanks for the help, Cj.
That's the FIAV, Fast Idle Air Valve. There's also the Idle Air/Speed Control (IA/SC) next to it, coolant doesn't run through it though. You can run without the BCS, no problem, but if the solenoid's unplugged you'll probably get a CEL.
1g CAS are green/black depending on the year. The 95-96 CAS are two sensors the cam and crank where the 1g CAS all in one.
Junkyards, part-outs & etc
