420A Semi Clean eBay turbo build
DrewmHolland
171
36
Apr 11, 2022
franklin, Tennessee
Just thought y’all might wanna see my built 420a… here’s the specs
Wiseco 87.5mm pistons 8.8:1 compression
Eagle rods
MLS .010 thicker head gasket
Stock head bolts
25% Underdrive pulley
eBay to4e turbo .63AR exhaust .50AR compressor
10psi non intercooled for now
93 octane gas
24lb/hr mustang injectors
Spa turbo adjustable FMU at 65psi on full boost and 28 at idle
Currently using 20w 50 VR1 as the oil gets very hot
I see 15psi of oil pressure at idle after hard driving and 65-70 on a cold start
That's nice and all, but what exactly is holding your radiator in place? OMG
(That is not a DSM radiator and appears to have no support)
Hopes and dreams hold it in place for now I still have to fabricate some mounting brackets for it, I chose this radiator because it’s not plastic and the inlet and outlet are exactly where i need them to be but sacrifices had to be made
