SD Troubles
TSITurbo95
18
Oct 26, 2009
Ohio, Ohio
Ok, so I have a good understanding of SD, however I am just having some issues. . .
Ok, so I was maxing out my SD cells, with the correct injector settings. I had to lower my global in order to bring the cells down. Well here is my issue.
I am trying to establish my afr's so I can further tune, but when doing a couple pulls, each gear is different. I will set my 2nd gear afr's, but when third gear comes around I have to change those same cells by alot. SO I change them, but then it throws off my AFR's in second gear and such.
Only boost leak is a minor leak at the tb, but really is nothing to worry about.
  • For sale 4G63 Groden alum rods. Set of 4 with ACL bearings
    Groden aluminum rods. Set of four. 22mm small end. With ACL race rod bearings. Locating...
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
