EMS troubles
weird.
it says I can't upload my file !@#$%^_cal
then it says the only allowed files are .................................cal.........................
Is that the cal file that came with the car when you bought it or has it been modified?
Honestly you're better off starting with a fresh basemap and going from there. I'm surprised the car even started. Did it take a lot of cranking over before it fired up? Do you have a wideband? What injectors are you running? What intake temp sensor? Any other relevent modifications or sensors?
It took a hell of alot of cranking, have a wideband, GM 3 bar map sensor, GM IAT, Not sure what size the injectors are right now, I just left the car and my laptop at the shop to go home, but they are selectable in the EMS, Siemens Deka 7XXcc. MSD DIS4, Mustang 75mm throttle body w/TPS and IAC valve.
  • For sale 4G63 Groden alum rods. Set of 4 with ACL bearings
    Groden aluminum rods. Set of four. 22mm small end. With ACL race rod bearings. Locating...
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
