2G saturn alt help, please keep this one simple guys
TheFlashDSM
Supporting Member
1,106
358
Feb 18, 2010
stony brook, New York
there is way to much mixed information about this swap, and its making my ADHD really fire up LOL:rolleyes::rolleyes:
2g dsm auto, drag race build. (using a j racing alt. relocation kit)
MY CAR IS GUTTED, NO DASH, NO IDIOT LIGHT.
I NEED HELP TO MAKE MAKE THIS ALT WORK
diagram below is 97-99 2g dsm charging system
i got a 96 saturn sc2 alt. from auto zone.
i have a 3 pin connector for that alt, S (large red wire) F (brown, grey/white stripe) L ( brown, red stripe) (picture of my plug below)
there is no harness on my car anymore for the alt, im making a custom one
2g dsm ecmlink v3 full ecu
ecu pin #33 Generator g terminal to where
ecu pin #41 Generator FR terminal to where
(Thumbnail click to enlarge)
:dsm::dsm::dsm::dsm::dsm::dsm::dsm::dsm::dsm::dsm::dsm::dsm::dsm::dsm::dsm::dsm::dsm::dsm::dsm::dsm::dsm::dsm::dsm::dsm:
They are not connected to anything with a gm alternator swap. You only need to connect the three wires, realistically, only two.
okay awesome, i hope your hear to help, tell me what to connect to where, and od i need to do anything special for resistant due to not having a dummy light?
S is actually the "sense" connection that will connect back to your "alt sens" wire in the engine bay fuse box. This "senses" the voltage of the system and up or down-regulates the alternator. The F wire goes to the alt relay that's also in the fuse box. Those are the only two wires you need. This is how the oem alternator is hooked up but realize there are other ways to do this. I don't have the car in front of me but I'm pretty sure this is correct^^
"S" to fuel pump relay feed.
"F" to switched 12v
"L" isn't needed if you're not running a light as "F" will turn on the alternator.
i dont have fuse boxes, both interior and exterior are gone LOL, like i said car is bare minimum. but i found what i was looking for in this thread, it states how to do it with ecmlink to ignore the code i have been getting, but i under stand the concept of what the wires do, i just didnt know about the ecu pins and how they corresponded to the saturn alt. but i got my answer from https://www.dsmtuners.com/threads/saturn-alternator-causing-check-engine-light.369503/
Maybe we can add a reply to that article thread with wiring instructions... or at least post a link to another thread.
The last line says "Wiring is pretty straight forward, the large yellow wire goes to the F(black) wire on the saturn connector and the small black wire goes to the L(black w/ white stripe) on the saturn connector."
Yeah, I noticed that after I read it again.
Large yellow wire and small black wire on the harness side of alternator plug?
I just saw this.
The Yellow wire from the harness goes to the F connector (black wire if you're using a saturn harness) connector on the alternator.
The black wire from the harness goes to the black/white on the alt conector.
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
