SAFC wire up help needed for 88 Turbo Cordia.
USCordia
Jun 27, 2005
Dover, Florida
Whats up Gents. Need a little help from a SAFC gurus.:thumb: Im looking to buy a Apexi SAFC, but there is no manual. Even if there was there, is no listing for my car. My car is a 1988 Mitsubishi Cordia Turbo SOHC 1.8 with a 4g62. If one of you have the time, can you tell me what wires I need to hook up? Ive enclosed a pic of the ECU wire diagram from my 88 factory sevice manual.
Thanks.....
Here is the pic I hope.... I found a wire diagram from the SAFC. Here is the color codes:
Red Wire - Power
Green Wire -RPM Signal (Is this the speed sensor from the diagram below?)
Gray Wire -Throttle Signal (Is this the Throttle sensor out put I would use?)
Brown Wire -Ground (There is a note to hook up the Brown wire closer to the ECU then the black wire. From the diagram below, what ground wire would I use?)
Black Wire -Ground
Pink Wire -Air Flow Signal Output (Air Flow sensor out put from diagram.)
Orange Wire -Air Flow Signal Input
Ok splice in the power(red) and ground(brown & black) to the power and ground of the ecu. For the air flow output, you need to cut that wire. The cars output end goes to the airflow input wire of the afc (orange) and the end of the wire going to the ecu goes to the airflow output of the AFC(pink). For the RPM (green) it should go to where you have it on your diagram (I'm not seeing a different place it should go). The throttle wire(gray) it goes where you have it. When you set up the AFC you need to know if the throttel signal goes from 0-5 volts or 5-0 volts it should be the first one and for the rpm to work right you may need to set a 2 cyl. Good Luck
    • Sdcryan1
