1G SAFC help needed
xi Talon ix
238
Nov 24, 2006
Hughesville, Pennsylvania
i just installed an SAFC 2 in my 93 talon and it wont start. i used RRE's and have looked at a few write-ups on here on how to setup the SAFC but it still wont start. i have fuel and spark. the car will crank over fine and fire the first rotation but it wont start. i just put new BPR7's in it along with a Walbro 255 and Fuelab AFPR. the O2 sensor is brand new if that matters. im still running the stock 450's for now so i can get it running but will soon be tuning with a set of 650's. can anybody help walk me through the setup and tuning as i am pretty new to the tuning world. any help is appreciated and thanks in advance.
Make sure that under the etc menu setting setting #1 is set for option 4 (karman) and setting #2 is set for 4cyl.
Yes! and make sure with setting #2 the Arrow points upwards. Make a video just like the last one but take us through the etc. menu.
Also, since you are on stock 450's you will want to pull all the corrections in the HI and LO THR down to 0. You should not have to correct for anything at this time unless you have a 2g MAS but that isn't listed in your profile.
nope i still have the stock MAF and 450's. it is set on Karman and 4 cyl with the arrow pointing up. ill make another video of the ect. menu and post back. thanks for the help fellas.
