2G SAFC 2 settings
mattspyder
1,046
Nov 2, 2004
del taco, Wisconsin
ok so ive checking the tuning guide and im alittle throwin off by this. i know how to set the th-points, but im stuck on where i set my corrections for the 650 fuel injectors that i have! what option do i go under in settings on my safc 2. im lost on that and this
for the NE points its says to set them to like 4.5 well mine doesnt have a 4.5 level it goes in 200's,
here is what i can adjust them to
settings
1 800 to 1800
2 1200 to 2400
3 2200 to 2800
4 2400 to 3000
5 3200 to 3800
6 3400 to 4400
7 4600 to 5000
8 5200 to 5600
9 5800 to 6200
10 6200 to 6800
11 7000 to 7400
12 7200 to 9800
now i realize i dont need setting 12 but, can someone please tell me how the hell i set this shit up
thanks
Im confused by your post.
You cant just set your AFC for 650 injectors. You need to manually change each RPM.
i believe 650's are 20% larger than stock, so you need to correct your AFC by -20 for each rpm. This will get you around town. You'll probably be running real rich so i'd recommend a good tuning as soon as possible. You need to find someone with a pocketlogger to tune it. If you want the tuning flawless, have it dyno tuned.
If you are still having problems with it, call slowboy racing and ask for nate. hes amazing with that electronic tuning shit. he'll help you out.
  • For sale 4G63 Groden alum rods. Set of 4 with ACL bearings
    Groden aluminum rods. Set of four. 22mm small end. With ACL race rod bearings. Locating...
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
