S16G boost levels
Status
Not open for further replies.
ypnas777
301
Feb 24, 2003
North Andover, Massachusetts
how much boost can I run with a small 16g and all supporting mods including dsmlink, fmic, etc. on 93 octane. thank you
according to the compressor map and approximate figures, that turbo can make good efficient power until around 24psi. You could run more but you wouldnt make much power.. Im new at the compressor map deal but i think i figured it all out right, someone with more experience might want to verify that this is a decent approximation.
On our small 16g car, we run 21psi at 5800ft. 91 octane. Dsmlink and supporting mods.
Steven
Because the DSMlink is sitting in my backseat. I'm still waiting on my injectors to come in to put everything in. Just wanted to get an idea on how much boost I could run.
dont you think 16-17 is a little low? I have all supporting mods including fuel pump, injectors, FPR, Dsmlink, fmic, etc. I was thinking maybe 20-21 on a good tune with 93 octane.
Just for your own knowledge:
Small 16G vs. 20G
Light green = S16G (unported)
Red = 20G (unported)
No one can answer your question, every car is different especially the modded ones, get all the supporting mods in then post dsmlink logs if you need help. Asking how much boost you can run is basically bench racing.
Status
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G ECM Link Speed Density Harness
    NEW 1G ECM Link Speed Density Harness $45 + shipping & paypal fees* these are $65 online * I...
