E85
- 0
- Oct 9, 2006
GBG,
Europe
Hi, I'm a n0ob so I can't post in the performance/tech forum yet...
Anyway, I need a new IC and I have to choose between a S/S or T/B IC.
I understand that S/S gives better cooling and T/B gives better flow.
Of course I want the best of both worlds but there is a catch.
I need the Connections to be on the same side.
Thus the question is how does a S/S IC that doubles back on itself compare to the T/B IC? (Flow in through the top half, Make a U-turn at the other end and flow out through the bottom half)
This will take things to the extreme making it a VERY long IC.
Of course I'll go with a bar/plate IC, there really is no other way.
To minimize flow restriction I'll need the best flowing IC on the planet.
Which brand gives best flow? Least pressure drop...
Opt #2 the T/B IC:
To get enough cooling I'll accept a core with a slightly higher resistance.
Wchich brand will give great cooling without to much flow restriction?
Given these options, how will they compare?
Which core from what brand should I choose?
Opt #2 the T/B IC:
That's a good point. A 14b/16g J-pipe designed for a frount mount is a far sharper and less progressive bend than that end tank.
