s-afc throttle reading percent
talongod
274
Nov 24, 2002
Mayfield Hts., Ohio
I got my s-afc II installed at a local shop and works fine except for the throttle percent is at 0% idle and jumps to 100% everytime i touch the gas even if i just tap it or rev up 100 rpms it shoots up to 100% any input please
thanx in advance
I am in that same boat with my SAFC. The shop here thinks that it might be the TPS giving a bad signal. So there working on it and will let me know. Then I'll let you know if you haven't already figured it out. :thumb:
Have you guys thought of just doing it yourself and saving some money? All you really need to do is follow the steps in the tech section. Misc. things you may need, solder, solder iron, heat shrink, heat gun, electrical tape. Its really not hard, kinda like an art, the art of soldering ROFL
someone with a data logger will be able to tell you if you're TPS is giving a bad signal alot faster and alot cheaper than a mechanic will.
ya the shop said it was my tps but my logger reads my throttle readings correctly so i might just have to take a look at the wiring
    • george bromwell
    • pma1123
    • Sdcryan1
