weird AFC throttle reading
xreaction122
258
Oct 28, 2007
Albany, New York
okay so my safc(I) has been reading the throttle way off.
when i start the car its at 0% then the reading jumps about 0.5% per second and when it reaches around 77% it just stays around that area constantly.
i put a brand new TPS sensor in and no good. its doing the same thing
ive checked the voltage and everything..wtf is wrong...:cry:
has it ever worked right or is this something that developed over time?
it always has been doing this but i dont think its a bad sensor ground since the reading never reaches 100%. like i said it stays around 76~78% constantly.all other sensors are functioning properly. but i will get my friends logger and do a log and let you know how it turns out
have you checked to see if the plug inside the afc is pushed in all the way?i've seen a few that have been pulled out just a bit and it makes the afc act up.
re-tested the harness and the actual sensor today. tried a third tps and still doing the same thing. :notgood:
someguyonline-im gonna have to get back on that tmw since thats the only thing i havent checked yet
Like a guy above me said, it is most likely a wiring grounding issue. Try to find the ground wires and test them on a known good ground
  • Wanted 6 bolt NT water pipe
    • chrisman287
