2G Rust repair
Yep get a cut off wheel make sure to cut about 1/4” past where the rust stops so it’s clean metal. Go to Menards or Home Depot and buy some 1/4” sheet metal cut out the shape u need leave a little extra space then weld it in. If u don’t have a welder u could rivet the sheet metal in and use a little bondo aka body filler to hide the rivets
U would not believe the crap this guy had me fix LOL and also may I add I’m a mechanic not a body guy I just did what I could LOL
If you find yourself in the city, take a look at the cabs while your in traffic, the stuff they do to maintain their general shape and keep them yellow is so brutal....
If you do not weld, SEM makes some great product for doing patch work. To source some good steel to make pieces, stop at a local junk yard and buy a cheap fender, or cut a chunk from a hood......much better than anything you will get from HD. The SEM stuff is also good for areas that you just dont want to go bringing the welding heat into, areas, where you dont want to burn the backside. Nothing wrong with using a rivet here n there to pin things in place while you work the metal into shape.
Its really easy to waste time and money if you go guessing on how its done, look things up and make sure your making good decisions
