Running Lean
Chris05
Jul 4, 2010
Humacao, Puerto Rico
Ok my fuel upgrades are a Walbro 255 and a fuel pressure regulator... fuel is running a 42 psi and turbo is at 10 psi... pyrometer goes to like 11 at 55mph but when I step on that pedal it while raise to 13-14 at 6,000rpm... I took my car to the dynojet and Air/Fuel is below the line... Running Lean?
stock injectors are already maxed out nearly on a stock setup. basically, you need bigger injectors. at 10psi, you shouldn't need anything larger than 650cc.
I've run 15 ~ 18psi on a 14b with 11.5 AFR's just fine on 450's. I wouldn't say 10psi is maxing out the stock fuel system, assuming he has 450's though.
