TheRealist
- 464
- 3
- Dec 12, 2005
Chula Vista,
California
Is this bad? can it couase back pressure major boost leaks? i have a 2.5inch downpipe already installed but looking for a 3inch exhuast system
Boost creep gets worse as you lower your boost controller setting, meaning the difference in peak value and your controller's setting will be larger. EvoIII's really like to run above ~16 psi if you're running an internal gate. Upgrade your fuel system so you can turn up the boost and you'll most likely see the problem disappear.1997turbodsm said:Since i have this setup on my car let me tell you a little of what you want to know. With my Stock Exhaust running an EVO III 16G i had no boost Creep. Now i've got a Megan Racing 2.5" to 3" DP and a Greddy 3" Catback. I'm Creeping like it aint nothing. I've got my boost controller turned off and i'm running 12PSI until i hit around 4500rpm. then my boost goes to 13....14.....15.....16.....17....18......19 around 7000RPM. I've got a stock Fuel Components so i'm kinda limited to what i do right now.
