Run a NA with a turbo Harness???
johnboyrs
59
May 28, 2011
brownfield, Texas
As many of you know Im trying to do the swap from no turbo to TURBO haha, any who my question is can I switch out my 92 non turbo harness to my 92 turbo harness without doing the swap just yet? Will my car still run with the nt ecu and engine?? Any advice would be most apreiciated.
Not really. The turbo harness is setup for an injector resistor pack low resistance injectors, and different maf that won't work with your stock ecu.
so i have to go full turbo...I have everything except turbo pistons i have a 92 gst donor car.
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
