NA clutch in a turbo transmission
I have 2 identical eclipses a 93 turbo and a 92 NA 4g63. The NA is being parted and I want to try and use the brand new stage 3 clutch that is in it. I have a stage 2 in my turbo and It has quite alot of miles on it. If it will work, why not? are there any differences?
He said nothing about changing flywheels. The flywheels are in fact different but the clutches are interchangeable. You can use your "Stage x" clutch from your n/t in your turbo.
They're not, but hey, its not like I don't have more rep points than you, or have had a n/t 5speed, so I'm probably full of shit. I'll forget more about these cars than you'll ever know.
OP, go ahead and try to change them, then once you have taken the effort to try, post back here so I can say I told you so.
So your saying that the NA clutch will not mate up to the turbo flywheel in the turbo transmission?
Ok...didn't mean to offend you in any way. I've been through my fair share of n/t 5 speeds my self, and neglected the fact that they ARE different. Sorry to misinform the op. Looking back on it now, when I did the swap on my n/t to turbo transmission I had used a turbo clutch. But when utilizing the n/t trans you will have to buy a n/t specific clutch, such as a Centerforce or equivalent. When switching to a turbo trans in your n/t you will need the starter plate, flywheel, turbo specific clutch, and the transmission mount.
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
