Rough Idle, wierd sound as accellerating...
sillybubu
Mar 26, 2004
Ottawa,
its been 2days.. i own a 2G Eclipse FWD.,,..i'm trying to figure out why my car isnt running smoothly..
The car came out of storage/shop a week ago.. now the car idles very rough..but the RPM is sitting at the right area.. 700-800rpm.. its not surging, the car does not sound right when i press on the gas, it sounds almost like a muscle car...
I tryied....
adding new fuel with a fuel system cleaner.. (Penzoil Fuel System Cleaner, Premium Pump Gas)
Changed my oil (Royal Purple)
Plugs were new from last fall (NGK IRIDUMS)
New Plug Wires (Accell Thundersport 3000+)
I did remove my boost gauge and it has not been replaced yet.. could that be the problem? does missing boost gauge = boost leak? = car running bad??
HELLLPP!!
you said that you had it in storage/shop, how long? was it there for a reason, say installation of a BOV? what type of BOV is it exactly? does it recirculate or vent to the atmosphere? Is your car's CEL on? Possibly an O2 sensor. is it an aftermarket boost gauge?
I tryied....
HELLLPP!!
Yes if you did not plug the boost guage source it will give your car fits.
You might want to check your timing. Tell us what it was in the shop for, and maybe we can help you diagnose the problem. Plug up the line for the boost gauge. That's a start.
Yes. make sure you have no boost leaks, so fixing the boost guage is a priority. Also, remember body shops have alot of dust, maybe something got sucked into you intake :( hope it didn't. but you never know. I would say that if you CEL were on, it could possibly be the O2 sensor. they will make a car run pretty crappy, I can tell you that from experience.
Make sure your MAF is plugged in.
Make sure your plugs are gapped correctly.
Do a boost leak test (after you plug the gauge source off)
Your problem will more than likely be fixed after ^^^ if not post back. But please, follow ALL of the above before posting back.
  • For sale 4G63 NEW Stop Tech Drilled And Slotted Rotors
    New Stop Tech Drilled & Slotted Rotors $70 + shipping and paypal fees* FITS * Eclipse GST...
  • For sale 2g 2G GSX/GST Manual Transmission Steel & Poly Mount
    2G GSX/GST Manual Transmission Mount (Steel & Poly) $45 + shipping and paypal feesYou must be...
    • sanmantsi72
    • El_marto
  • For sale 1G DSM 4G63 PARTS
    • The_Partout_Spot
