Rough Idle then dies when I hit the gas
dsmrebel084
114
Mar 4, 2011
st.louis, Missouri
Ok so after incident I got my car back started n now tht its getting proper gas pressure it has a rough idle n dies wen I hit the throttle. So I'm lost on wats causing thz so any pointers will b appreciated
Do you live in South County near Lemay? I see a white talon around there alot and may be able to help you out if I you live close.
Ah man there is a white N/A on my GF's street that stares at me everytime i go by. Where in Noco, florissant? My car will occasionally do this when its hot but it wont die, it just bogs a bit. I use copper plugs, It might be time to get new ones.
First off, can you give us a bit more background on you vehicle? Mods, maintenance, ect.
Next, have you done a boost leak test?
Edit:
(Double post fixed, sorry I'm on my crappy HTC hero.)
I had a problem with my front o2 sensor, it was hooked up incorrect. The car had no to very little power. When the car seems like it was about to die, i'll give it gas but it would die. Since im guessing you have'nt installed a new o2 sensor, it could be bad and need replacement.
I live n Spanish lake but rite now my car is not turbo'ed yet...I got the thing hella cheap n I got it running...once I got it running I did a full tune up on it and the only mods I hav is a cold air intake and a full exhaust
Sorry, says you have a turbo. Since that's out of the question, try a new o2 sensor, new wires and plugs, make sure its all firing correctly, and check for any possible vacuum leaks.
If all passes well, I would check fuel, change fuel filter,see if injectors are working properly, fuel pump is good, and see what you have from there.
I'm not telling to do all at once, just work your way down the list to slowly narrow the possibilities!
Good luck.
Good luck.
Ok...I changed everything..new o2 sensor wires injectors plugs but ### I also 4got 2 mention is tht I redid the whole fuel system. It has a fuel cell wit a 190 pump n afpr. And the problem started lik a week ago once I let the battery die on mii
My phone would have put the "o" in "sorry".
No excuses. Don't expect help if you can't take the time to ask like an adult.
