Rough idle / backfire
Are you using a 1g CAS? Also check your injector harness one could have cam off resulting in only running on 3 cylinders.
Injectors are new (remanufactured ) stock
It gets to a certain rpm then it seems to miss and backfire. I had the same thing happen to my F150 it would get to a certain rpm then miss like hell, but once I got past that point they would work better. Coil pack was bad. I tested the spark on my GST, and got good spark. If the pack is going bad, I would still get good initial spark right? Then it would crap out under load?
I am swapping today. Fingers crossed
UPDATE: It does the same thing. The header paint melted off cyl. 1 & 4, but nothing on 2 & 3.
Any ideas?
I am running NGK bpr6es, since I have upgraded my intake and exhaust, should I go with NGK 7es?
No, I have been having this issue for a while. even before I put in the new CAS. I just ran it long enough to get it that hot.
cyls. 1& 4 are running lean. (either no gas or no spark in those cylinders.
