Rotten egg smell
crazycarls97gst
Dec 13, 2002
Tinley Park, Illinois
Im just wondering if anyone knows, or has any idea of why when i get on it hard. I get a rotten egg smell right after im done gettin off it. I think it might be the cat but im not sure any suggestions would be good.
Originally posted by marksae
What would cause a cat to smell like rotten eggs?
Hydrogen sulfide, the same thing that gives rotten eggs their smell. I have biochemistry tomorrow and I can get the full scoop if your interested. I'm sure someone on here has the chemistry background to explain.
Later,
Chris
I would reccomend using up your current tank of gas and than switching to a different station. My guess is that it has to do with the quality of gas you are using. Not all gas stations are equal. With my GTI I filled up at a station near my school twice and noticed a rotten egg smell both times, I started going to a different station and it never happened again.
alright does anyone know where i can get a test pipe cheap like really cheap cuz im kinda sick of smellin eggs. And would i have to stay with the stock diameter pipe or could i go wit a 2 1/2in test pipe so i dont have to buy a new one when i get exhaust
www.testpipes.com i believe.. also, you could go to your local exhaust shop..
Definately your Cat'. One gas station that I know to stay away from is "Shell" stations. Ever since I had my Cavalier back in 96', then my 98 Eclipse GS, and now my 97 GS-T, Shells' gas burns super smelly like that. I stick with Exxon. I don't get it as often.
Check under the seat for an egg crate you may have forgotten :D
j/k
My buddie's GSX had smelled like that after 'getting on' due to a leaky BOV. It would leak mad under boost, and the air that has gone through the filter, hot turbo and dirty IC doesn't smell too go0d :D
It could be your battery as well. If the acid leaks out, it smells like rotten eggs. My car used to explode batteries. Just look at it and smell it and you'll know.
  • Wanted ISO Leveling valve assembly, Mitsu part MR135668
    Just bought a 98 Eclipse, while removing the fuel tank I accendently broke the Leveling valve...
    • briang26
  • Wanted 2g Trunk/fuel door release lever
    Looking for a 2g black fuel door/trunk release lever in good shape
    • jesse12345
  • For sale 2g parts
    Evo 3 Big 16g, xs power t4 manifold, various other parts
    • heresjimmy42
  • For sale 4G63 3 inch Magnaflow SS high flow cat. CA approved.
  • Wanted 1g 6bolt Balance Shaft
    Does anyone have a rear balance shaft for a 1G 6bolt hanging around? For some reason, this one...
    • Gabe92RTTT
