Rotor Replacement
PFC_CiarlilloM
234
May 22, 2011
Euclid, Ohio
Okay so im replacing my rotors and i took the caliper and the caliper frame off on the rear. The rotor should just slide off then correct? because its not and I think its just rusted on but I want to make sure there isnt something else im missing. Thanks!
Mike.
some times the ebrake is adjusted to tight as well. you can spin the adjuster and back it off. another thing is that if there is a big rust ridge where the shoes ride on the inside of the rotors for the ebrake can build up and its a PITA to get it off. i usually have luck with a 3lb dead blow hammer. also spray around the lug nut studs and the center of the rotor with pb blast and let her soak and try.
buy a can of pb blaster and use the whole thing on them. wait a few hours and bash them with a hammer. that stuff is the best. if it doesn't work let it sit over night, the rust should be gone by then.
oops too late LOL
Pb blaster & some nice whacks of the sledge hammer normally gets it off for me
  • For sale NEW Magnus Forged Transfercase gears
    Parts are new never used. Get some nice parts for a couple bucks off.If I don't replay right...
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
