1G Rotor not sitting on hub
guamboyeli
125
May 24, 2012
North las vegas, Nevada
I put Evo X calipers and rotors on my 1gb... My problem is that the center hole on the Evo rotor is bigger that the hub, so the rotor sits in the studs and not on the actual hub... Can anyone help me out here???
youre going to need a hubcentric ring to center the rotor properly. measure the hub and rotor to find the inner diameter and radial thickness of spacer youll need. its possible you may need to have the rings fabricated.
you would get the inner diameter of it for a dsm, but the outer diameter will have to match the rotor (evo). i dont know of any made that way, hence my saying you may need some custom or customized spacers.
Well I did some measuring and this what I came up with... How much spacing should I need so I can see if strictly's is enough??? Half inch???
