2G Rear not sitting level
Aproductions
2,123
50
Aug 11, 2009
Allentown, Pennsylvania
I have the car on sportline springs and the rear looked to sit level until I just used the rear camber kit (washers and bolts). Anyways does it matter where you tighten the bolts in the picture? I feel like I tightened one side higher than the other.
64185 and 64184 are the ones I am talking about.
I had the car jacked up when I tightened those bolts. Then I dropped it and it is higher on that side. I am thinking it is not settling because those bolts are too tight. Would that make sense? Should I put a jack under the knuckle and compress it up and then tighten them?
