ECMlink Rich at WOT
Anthony Yacullo
148
3
Aug 20, 2014
Reseda, California
1). Any boost, vac, or exhaust leaks?
No
2). Verified mechanical timing?
Yes
3). Verified base timing?
Yes
4). Ignition system
COP or Stock Coil: Stock
Wire brand and Age: NGK 3 months
Spark Plug brand, type and Gap: NGK-BPR6ES/.027
5). Motor health (Compression Test)
Cylinder 1: 123
Cylinder 2: 127
Cylinder 3: 119
Cylinder 4: 124
6). Performed basic throttle body adjustments?
Idle Switch: Yes
Throttle Cable: Yes
TPS: Yes
BISS: Yes
7). Compression ratio
stock
8). Any known bad sensors or brittle wiring?
No
9). Any DTC/CEL codes?
No
10). Electrical system
Car off (not running): 12 volts
Car running: 13.9 volts
11). Base fuel pressure and injector values
Base Fuel Pressure: 43.7
Injector Size (cc/min): 450
12). Properly calibrated and configured wideband sensor
Sensor Brand: Aem Uego
13). Type of fuel
Type: 91 Octane
Percent of Ethanol:10~ish
14). Watched ECMlink how-to videos?
Yes
I tried to get a long log this was taken on the highway.
Your commanded AFR is 9.2 and your AEM is reading 10.0 so you are actually running leaner than anticipated.
At 5700 RPM you are at 95% injector duty cycle. At redline, I would venture to say your above 100% IDC? You are out of injector. If you try to run richer than you currently are, you will tax the injectors for more fuel which you do not have.
Due to the low RPM and higher speed, I assume this was done in 5th gear? 3rd gear pulls are what we like to see for tuning purposes. You also want to keep your pedal to the floor to eliminate the TPS fluctuation seen in this log.
Load the attached table and lower your boost a few lbs (to keep your IDC below 100). Go out and make a third gear pull to readline watching for knock and post up that log.
Not sure how I skipped over that. The FSM calls for 178PSI with a service limit of 133PSI and no more than 14PSI difference.
All of you numbers are below service spec.
This was actually 3rd gear just was on the highway.
Edit: ideally you guys would like to see a 3rd gear 2k rpm to redline right?
Ya honestly I haven't done a compression test, I know the motor is heathy tho.
So you blatantly lied and filled out the requested form with false information? If this is the case, I will not waste anymore of my time trying to help someone who will not help themselves.
You “knowing" the motor is healthy tells me and other members nothing about the actual mechanical condition of this engine. How many of the other things did you actually check before filling out the above template? I suggest you actually do the test in the template above and start another thread with actual results.
  • For sale 4G63 6 Bolt ARP Head Studs
    ARP 6 Bolt ARP Head Studs $65 + shipping & paypal fees* these have been torqued onceYou must...
  • Wanted 2ga side markers
    Looking for 2ga side markers
    • Rohitter7878
  • For sale 2g 2G Fwd Thermal Research exhaust
    2g Fwd Thermal Research cat back exhaust
    • ari2gdsm
  • For sale Used Tial 44mm wastegate
    Looking to sell my used Tial 44mm wastegate. Legit Tial gate, verified by Tial. Can send...
    • Anfurnyy
  • For sale 1g 1g stock mass air. 4G63T.
    Stock 1g mass for turbo. Car ran was all stock. Hit in the rear quarter hard. 92 Tsi. Pulled...
