WOT rich dip
sk8freak8989
46
Jan 28, 2010
sterling, Massachusetts
I just finished installing my holset hx40 setup and I started to do some tuning last night. I am haveing a wierd rich dip at about 3000-3200rpm. If I start the pull at 2500 the car will switch to open loop and have an AFR around the 12's. Right when it reaches around 3000 my wide band will drop to about 9.3 and the car will bog. At around 3200-3400 the car just snaps out of it and goes to normal wot afr. With the holset swap i changed to FIC 1250 injectors. Is this just a thing with big injectors that is unavoidable? I have already tried pulling fuel out, but so far the best i can do is get it to only dip to about a 10 AFR. Any info would help.
Thanks
I can get a log tonight but i do not have my wideband logged. The only thing I did to try to get rid of it was pull some fuel out of the fuel table where it was happining. I got it to lean out to about 10:1, but the car still bogs down. What do you guys think, is it tune related or maybe bad injectors. I got the injectors used so that is why I am wondering. I have tuned the car before with a 16g and 680's and had no problem. I am wondering if it could it be a big injector thing?
What base settings did you use for latency?
  • For sale 4G63 6 Bolt ARP Head Studs
    ARP 6 Bolt ARP Head Studs $65 + shipping & paypal fees* these have been torqued onceYou must...
  • Wanted 2ga side markers
    Looking for 2ga side markers
    • Rohitter7878
  • For sale 2g 2G Fwd Thermal Research exhaust
    2g Fwd Thermal Research cat back exhaust
    • ari2gdsm
  • For sale Used Tial 44mm wastegate
    Looking to sell my used Tial 44mm wastegate. Legit Tial gate, verified by Tial. Can send...
    • Anfurnyy
  • For sale 1g 1g stock mass air. 4G63T.
    Stock 1g mass for turbo. Car ran was all stock. Hit in the rear quarter hard. 92 Tsi. Pulled...
