Review: SCE ICS Titan Head Gasket
The one i was using started having sealing issues after letting it sit all winter. It probably would have only need a retorque, but i needed to pull the head for other reasons so i replaced it with a felpro composite gasket. I wouldnt be afraid of using another one in the future, but i would retorque it every spring.
Well guess I will make this one available then and just get a Mitsubishi MLS
. Don't wanna deal with the maintenance.
I considered using it but after taking to MAP I decided not to. It's more of a track only gasket that requires constant attention. Stick with a composit or OEM/Felpro MLS gasket.
Care to share what MAP told you? This thread doesn't suggest that.
I just received my SCE Titan gasket from MAP along with the MAP Head studs. MAP's customer service is AWESOME!!!!
While putting the gasket on (Part Number S91524 - which is the correct part number) I saw something kinda odd that I would bring to everyone's attention.
I already put the head on and torqued them down but was curious if this may cause an issue...
Yellow was a bad choice for highlight color LOL
It appears to be like that in the opposite diagonal corner as well. Personally I would have just trimmed the gasket to have it line up better especially the other hole being an oil port.
I would not have recommended this gasket however since the copper is so soft you will need to constantly check and re torque the head studs to ensure a proper seal. It's more of a race gasket.
I do hope it works well for you and you don't have any issues.
Modern Automotive Performance is where I buy my parts and they do have excellent service. Consider writing a vender review DSM Vendors - Directory
I wonder if MAP is still highly recommending this copper gasket? Glad I sold it and went with the power enterprise one I am using
  • For sale Wideband
    • Briant91
  • Wanted 560 injectors
    • AllanL
  • For sale ACT clutch 2600
    • Briant91
  • Wanted 2g 2g awd rolling shell
    I’m looking for a clean 2g awd rolling shell.
    • DSM_Thorpe
