Reusing turbo -> manifold bolts and stud?
joosdawg
187
3
May 8, 2005
Appleton, Wisconsin
ok well i just got done tracking down and buying everything to swap a 14B onto my 2g. i got every new gasket, j pipe, ss oil feed ect for tons tons tons less than a stupid install kit. anyway, the only thing i didnt buy is new turbo to manifold bolts. has anyone else reused the 3 bolts and one stud? i dont really want to unless i hear that its ok to do so from somone as i have $5 left after buying the turbo and parts and wont have more money due to child and life expenses. this was my kick to find all the 14b parts for the $160 that i had and i got everything but those bolts :\. so id really like to hear that i can reuse them ;) ;) but if not ill have to sell somthing else to buy them LOL then hope there in by friday when i planned on starting the install... -Ryan
*edit* also what kind of bolt and nut combo do i need for the j pipe to bolt up? aka length size, certain grade or can i just pick whatever looks like it will fit from home depot and put a lock washer on?
when i swapped my 14b in i bought 4 new bolts and eliminated the stock stud.
try to save up a little more and put them in at once so you dont have to worry about them breaking in the future.
another reason to get new ones is that they might snap on you when you're almost done and start to torque them down.
Give a call over to Renner Mitsu in Milwaukee.
Mention the club DSM discount and they cut 20-25% off mitsu cost.
Not sure how far appleton is, but you could even drive there and pick them up... of course they ship parts too.
Those bolts are kind of special... very strong and withstand heat... wouldnt be a bad idea to dab some antisieze w/nickel on the threads either.
-Chris
You should not reuse the turbo bolts when removing/replacing the turbo and definitely eliminate the stud.
its all good thanks for the replys i went ahead and ordered 4 new bolts from slowboy there due in on thursday ;)
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
  • For sale 1g 1990 Turbo Throttle Body ( rebuilt )
    1990 Turbo Throttle Body $85 shipping & paypal fees* this throttle has been rebuilt and is in...
