Reuse block from spun bearing?
Which bearing spun? I've reused several blocks that had seized or spun a balance shaft bearing, I just eliminated it and went forward. If it was a main bearing I'd have a machinist check it out, but because of the materials used it would more than likely destroy the crank before the block saw any damage.
vr4 scott, do you know what a spun bearing means? When the bearing spins, it locks onto the crankshaft and spins around in the main cap and block, when you spin a bearing it is not just put a new bearing in and send it, you need a decent amount of machine work, most of the time, you need to shave the main cap, saddle the block do a main line hone or bore if really bad! Labor work adds up! Some times it is cheaper to just find a good block.
agree, along with get the crankshaft turned based on the condition.
Yes I agree. Definitely take the block to be machined and go from there. Cause in the time you take to find a good bare block you could have it back from the machinist.
