(resolved) would a bad o2 cause high idle?
PIMking
2,781
4
Jan 29, 2008
tuscaloosa, Alabama
Okay I have another high idle thread. I have searched and tried everything. Now I just loosened (sp) the cable that seemed to work right away but I havent went for a drive.
Usually when I slow down it sits around 2k for 5-10 seconds then drops to normal.
I have weird o2 voltage and I am getting a new one tomarrow (had to order it since I was not going to use an universal one) but will that cause a messed up idle?
I will also change plugs agian and put some new wires on tomarrow. Im just lost. Am I chasing down the right leads.
Plus I have done everything else from BLT vacuum test and all the good stuff. I know the ECU is good I just had the caps changed a month ago when I purchased LINK.
let me know what you guys think.
I will find out if the throttle cable did the trick.
It breaks up at low throttle and 1992awdlaser says it looks funny. So I will get a new one tomarrow with new plugs and wires. I will update tomarrow.
The throttle cables did the trick. Also a new o2 and plugs. The other plugs smelled a bit like fuel.
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G ECM Link Speed Density Harness
    NEW 1G ECM Link Speed Density Harness $45 + shipping & paypal fees* these are $65 online * I...
