can bad o2 cause rough idle & masive loss of power
Status
Not open for further replies.
91monstertalon
Dec 4, 2007
jacksonville, Florida
out of no were my car is running like crap.. all my main vacume lines are connected. the only thing i havent checked is o2 boost leak test and compreshion test...and when i mean my car is running like crap i mean super crappy no power under load any ideas?
The things I would consider most look at the t belt to see if the timing marks are right. Do a boost leak test as well with soapy water. You should be able to build the boost to 25 and let it leak out very slowly. if you cant build up to 25 they you have a leak or the air pressure needs to turn up on the compressor. A bad o2 will cause power loss but shouldnt be that much.
when mine did that black smoke rolling out of the exhaust no power at all ......i thought it was a boost leak ended up being the ecu,replaced it and it ran fine .....no my tcu is bad LOL stuck in 3rd gear
You sure its your TCU? My car is an A/T and was stuck in 2nd gear and would sometimes randomly shift. I just changed the Tranny Fluid and it shifts perfect
When everyone finds the spell check feature on their respective Internet browsers (yes, yours has one) we'll open this one up again.
Until then, boost leak test, change plugs and wires to the proper plug and gap, compression test/leakdown test, and if that fails, take it to a certified auto technician for a free inspection. Many places will do it and give free estimates.
Good luck.
Status
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G ECM Link Speed Density Harness
    NEW 1G ECM Link Speed Density Harness $45 + shipping & paypal fees* these are $65 online * I...
