Rough Idle, Loss of power, P0340, P0120.
dyetrying91
105
Jul 2, 2009
North Haven, Connecticut
My timing belt blew at an idle last year around march, bent all 4 intake valves pretty bad. Swapped on a new known good head a few weeks later, car was running, albeit a little rough, but running no less, gas mileage was way down as well as a loss in power. Few months later, change out water pump as the reman I had done with head swap starting leaking bad. It runs and drives ok now, but there is still a massive loss in power, (difficult to even get the tires to spin in second), as well as terrible gas mileage.
The idle kinda sounds like I have 272's in there, but the entire engine is stock. I'm getting a tps code and a cam position sensor code. Really at a loss here, it all feels like a vacuum/boost leak, but I haven't been able to find one yet, and I have tried all the methods I could find, (smoke machine, brake fluid, Boost leak tests with soapy water)
Any help would be appreciated.
It sounds like you are running a little lean that will affect the way the car sounds.I would change the cam sensor and the tps sensor.Those will make your car feel like it has a loss of power.
