Can a bad o2 sensor cause Random Misfire?
Big Bald
242
Oct 12, 2002
Hamden, Connecticut
Ever since i installed this Bosch Universal o2 sensor i have bucking at idle. I am assuming this is linked to the recent P0300 CEL i been getting. This is the only thing i can think of.
Did you ever figure this out? My datalogger gets a max of .17 volts from the 02 Sensor so i assume is dead ... and on the same note it is misfiring at random (but pretty often) after my 6 bolt swap. No RM CEL however... runs great once you get going. It does idle like crap.
any advice?
A bad o2 sensor can cause a number of affects with a car. Youd be surprised how much it could affect the performance of a car. So yes, it can cause some random misfires. If your still seeing some volts from it i doubt it will pull a CEL. It wont be long before it does tho :talon:
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G ECM Link Speed Density Harness
    NEW 1G ECM Link Speed Density Harness $45 + shipping & paypal fees* these are $65 online * I...
