Can a bad Oxygen Sensor cause these codes.
805LegendDSM
84
Apr 14, 2011
Oxnard, California
P1104 p1105 p0505
Malfunctioning of a FPR and a idle valve, as well as a wastage acuator?
I just bought a 95 GST auto 2 days ago and checks the codes just a few minutes ago...then deleted them.
After the research I seen more than one thread about an O2 sensor causing these codes to pop up causing a CEL.
UPDATE: ok I deleted the codes after a few minutes of driving only two came back...
The Idle control valve and the waste gate acuator...
My idle at cold starts surges for air it goes up an down then when it gets warm enough the car idles fine, the wastegate acuator I've had before with my 95 GST in 2010 with a 16G untuned I deleted/replaced the Stock BC with a Bloc MBC and it never came back?
My car doesn't pass smog due to what I was told a clogged or rotten Catalytic converter can any of these codes relate to that?
  • Wanted 2g 2g Hood latch support
    On the hunt for the support that holds the hood latch assembly.
    • jesse12345
  • For sale 4G63 Hallman ES Boost Controller
    Boost controller
    • jpturbotalon
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
