[RESOLVED] wiring harness and vacuum lines
slim2005
119
Dec 8, 2007
Dodge City, Kansas
:talon:I need diagrams for the wiring harnesses on the passenger side of the motor and i also need to know what the vacuum lines are on the transmission region and diagrams for the other vacuum lines. Picture would be great too. I have a 2g turbo FWD talon.. thanks to all of you i almost got my car done. considering it had no motor a few months ago. i'm doing good i think.
:talon:ok the vacuum lines are underneath the air box and such. i really need to know where the little plugs that are on the wiring harness for the starter goes and any suggestions on hooking up the starter. i need those and good diagrams and pics for those issues and the vacuum canister things on the firewall and the vacuum lines on the intake manifold thanks to all who help.
thanks so much luv 2 rallye... can anyone help with the vacuum lines in the airbox area or the some of the wiring harness connetions on the same harness that goes to the starter...again thanks luv2rallye
i don't know where this pipe/ line connects. and the second picture i need to know where te two circled connections connect to. and the third i don't know where the two plugs go they are on the same harness as the thermostat thats why i drew the line on that wire.... thanks if you can help this is all i have left to finish up putting my motor together i hope:talon:
:talon:ok got the vacuum lines figured out just need help with the wiring now please and thank you all.
i only need to know the connector on the right hand side is cicrled in green turns out the one was the o2 sensor and the other two were actually intended to plug into one another.. thanks in advance if you can help.
ok i had my friend bring his 95 TSI AWD over and we got everyting figured out that way. now just gotta get a radiator.
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
