Resolved 2G Throttle Body vacuum lines?
nightstocker99
241
Aug 2, 2005
Saxonburg, Pennsylvania
When I took out my engine to change the clutch I hooked the throttle body vacuum lines up wrong can some one take a picture of how they should look or tell me what goes where. IMO a picture would save time because like some old fart sad a pitcure is worth a thousand words. :thumb:
:dsm:
:dsm:
http://www.dsmtuners.com/forums/showthread.php?t=198327&highlight=taboo+vacuum
This shows both stock and then also which lines you can remove and how.
Its a diagram, not a picture. Hope it helps.
If you look at the diagram the top is for your 2g stock routing. In the after picture you will see red dots, they are the spots you plug to eliminate the emission control.
That will be the best pic you will probably find anywhere. You can't really photograph the lines because they run behind the intake and all over the engine bay.
the vacuum lines have different color dotted lines on them and the throttle body has letters P E and A I believe. Matching them up would be the easiest way though I'm not sure which is which right now. you can search for it though
