Throttle body vacuum lines with SMIM
HiBoostGST
42
Oct 10, 2008
North Charleston, South Carolina
I have searched a lot under throttle bodys (there's quite a few) and vac lines and the Taboo guide about where the vac lines go on a 2g. I hope that i didn't miss it somewhere, so Mods if i did im sorry just point me in the right direction somewhere if you dont mind:pray:. I have a JMfab SMIM and am using the 1g N/T TB rebuilt from throttlebodys.com
What do i do with the vac lines? I was under the impression that i just block them off.
The emissions stuff was mostly unused when i bought the car.
Thanks for any help!
they go to your firewall there is 2 sensors mounted right behind the intake manifold on a 2nd gen
You can just loop them together if you won't want to run them to the right sensors.
I agree with him just cap them off or cut you lines short enough to route them back into each other pretty simple.
thanks guys, i figured that i would end up capping them off. i went back and looked, and i think all of my emissions sensors are gone already. ill just cap em. thanks again!
yeh i gotta open this one back up ... i orginally had a bbk throttle body on my gsx but it had so much shaft play in it ... yes i said shaft play the whole thing had space around the butterfly and it was junk so we put the stock one back on and now my car lopes up to 2k and I can't boost past 11lbs when its set at 18lbs and also I have a 3 nipples on the throttle body but i dont know where they go i want them to be hooked up properly ... any ideas ?
    • klipschaudio
    2g pass front rocker corner
    • dsmmario
  • Wanted 1g Fuel Pump Hanger Assembly, MPI Relay
    Current one is rounded off, kinked and crusty. Looking for a good condition 1G AWD hanger and a...
    • Gabe92RTTT
