Resolved NEED HELP: 90 and 91 wiring harness
Garman112
Mar 18, 2008
Reading, Pennsylvania
I have a 90 and a 91 awd i am looking to put the motor from my 91 into my 90... i hear the harnesses could be different, I need to know if the 90 harness will plug into all the sensors or if theres a difference? If there is a difference will i be able to switch the sensors to make it work? all help will be greatly apriciated thank you
There are definitely a few differences in a few of the connectors/sensors. I'm not sure if there's an actual list of them, but there aren't that many. You may have to splice a few connectors, etc, but not many at all.
Power transistor, tps, and isc are wired differently but not a huge deal. Simple cutting and soldering is all that is needed. Unless you use all the 90 sensors then you will fine. Only need to worry if you are using all 91 plus parts.
sorry I have a completely different gallant vr4 wiring harness I bought. i attempted to put it in my car until I noticed it was completely different when it came to the plugs inside the car so now I am car-less and dam its cold.
