[RESOLVED] What could this be...?
Robb
82
Apr 22, 2009
Harrisburg, Pennsylvania
Welp, I took the car to the frame shop today. I lifted the car with my wrecker and noticed the oil leaking. I previously thought it was the oil pan until I saw what it was dripping out of.
Now could somebody tell me what that is? My guess is something to do with the oil feed or return line for the turbo, but I'm not sure. What hooks up to the now leaking ends? And if you look to the right of the red circle, you'll notice a small broken bolt hole. Can anyone identify that too?
Normally, I won't have an issue like that, however this is my first turbo'd vehicle, so there are some new things for me to learn. Thanks in advance!
On the upper right hand side corner of your picture, the line you see there is your oil feed line. The oil return line is the tube coming down from your turbo to the oil pan. Welcome to DSM's :D
The picture is bright, but those fittings are supposed to be closed and tight and not leaking, i have never seen this before.
I'm not all that familiar with the the water cooled oil housing but that should just be a plug from machining the oil paths. Might just have to pull it out and reseal it. The broken "bolt" hole is just for one of those clip/wire holder things I believe. I have a 90 with the air cooled housing so I am just going from what I remember seeing before. Somebody with the same housing might be able to verify the info.
Yeah the broken hole is useless cosmetic to strap oil pressure sender harness to. Those fittings are unused and should be resealed with Teflon tape or something.
Yeah, unfortunately it's a vehicle I repossessed, so I really do not know what the previous owner was thinking or did to the car LOL
Does this help Rob?
In front of the pressure sender there's a plug. So it could be either, but you have no sender there.
