[RESOLVED] vital screw, need part # please \\ Turbo oil feed banjo bolt
Status
Not open for further replies.
Generation1JeY
547
Aug 5, 2004
San Diego, California
Hi i just broke the banjo bolt that bolts the oil feed line to the turbo to the head, i went to napa, home depot, autozone, kragen, and none of them have it. I live in san diego and i'm wondering where anyone would have this bolt. I already went on machv and ordered theirs, but i know it iwll take like a week and a half to get here and as of right now i cant drive my car because theres an oil leak.
Any hep appreciated
Check out RRE's website for the correct stainless feed line kit.
I am not looking to buy a kit. I am looking for the sizes needed for a banjo and bolt that will work on a T-25 set up.
I all ready have everything pictured above, except that the banjo and bolt are for a 16G, not a T25.
The T25 uses a internal flair fitting (like brake lines) so all the banjo stuff is out the window.:cry:
anybody know the part # for this screw?? :sosad:
MF650102, thats the original part number, its the turbo oil feedline banjo bolt, you'd also want 2 MF660063 which are the crush washers for it, hope that helps
wow, that was faster than i thought. :rocks:
thanks guys, especially for the fast replies.
I don't have the numbers you're looking for but you can get it at the dealership. Cost me $42 for one shipped overnight. :S
I dont know if anyone else has done this, but if this car is a daily driver you can make your own banjo bolt. I dont know the details, but my friend found the same size bolt and just drilled a hole in it. Basically the same thing, and much cheaper than $42.
This may be hard though, he has just about every tool avalible. I dont know what you're working with...
go to a yamaha dealership, and get a banjo bolt from a yamaha yzf450 fourwheeler. it'll be the 10mm banjo bolt(I believe) for the oil line that goes into the block of the engine...I had to replace mine and my uncle(who owns a yamaha dealership) found that one for me. it's ALOT cheaper then buying a mitsubishi bolt...it was like 9 or 10 bucks.
Knechts carries them around here. I would just get a SS oil line kit for he filter housing.
OK i need to know these 3 size's
banjo bolts for oil line to turbo
head on engine-10 1.25
going tinto turbo-
coolant line to turbo- i know its a size 22 mm bolt
1g 91 eagle talon tsi awd thanks!
10mm x 1.25 Thread - DSM Oil source from head
12mm x 1.25 Thread - Standard DSM Turbo oil inlet
14mm x 1.50 Thread - DSM Turbo Water Line
No problem. Is that everything you were looking for? Can order the banjo bolts/fittings through Forced Performance and I think extremepsi also carries them too.
Status
